Linux VS Windows
User avatar
Kpol
Linux VS Windows
Post by Kpol » Sat Mar 19, 2016 4:29 am
Onlyoffice is better on Linux or windows server ? Which one you (**REALLY**!) recommand ?? Stability, performance... I want it all! :D :D :D
Your sas service is host on a linux or windows..?
Re: Linux VS Windows
Post by Dean » Tue Mar 22, 2016 12:23 pm
Our recommendations are to use Ubuntu of the latest versions with docker - it is always easier to deploy and it works natively on Ubuntu.
SaaS version works just as recommended above.
User avatar
Kpol
Post by Kpol » Thu Mar 24, 2016 1:12 am
I see. thanks for infos.
PS : Is there plan to set onlyoffice docker access by httpS by default?
Post by Dean » Thu Mar 24, 2016 6:27 am
NO, it is totally up to our users to change it if necessary. They may have their own network configuration (in fact, they all do), so we don't have any permission think for them, if it is httpS what they want or not - they may have a local storage, or proxy settings. So the https may be not necessary for them.
User avatar
Kpol
Post by Kpol » Thu Mar 24, 2016 10:56 am
ok.
thx.
