Mono Crash after restart the server
Locked
ecrazor1911
Post by ecrazor1911 » Sun Mar 29, 2015 3:43 pm
I restart the server, after I open the web interface and I got a crash message:
2015-03-29 17_34_57-XenCenter.png (33.37 KiB) Viewed 9622 times
OS: Ubuntu 14.04.2 LTS
Mono Version: mono-runtime 3.2.8+dfsg-4ubuntu1.1 amd64
OnlyOffice Version: onlyoffice 8.1.232-5 all
Then I try running on Docker with fresh install, and the problem similar.
After I try reinstall Ubuntu 14.04.2 LTS, and I try install the latest version of OnlyOffice (deb package). After install the mono runtime crash.
Any idea?
Thanks!
ecrazor1911
Re: Mono Crash after restart the server
Post by ecrazor1911 » Mon Mar 30, 2015 5:38 pm
Problem "solved". I reinstall fully the XenServer VM after problem is solved.
th0mas
Post by th0mas » Sun Apr 05, 2015 3:30 pm
I have the same problem! Can you say a little bit more about you've solved this problem? I do a successful installation and start working with onlyoffice and after a crash in the middle of working with it, it crashed and throw this error. What can I do? Backup the data, do an fresh installation and hope the error doesn't come again? :(
I would be happy about any help
Best regards
th0mas
Post by th0mas » Sun Apr 05, 2015 3:49 pm
Here a lot of more log-output
Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
Unhandled Exception:
System.NullReferenceException: Object reference not set to an instance of an object
  at System.Threading.Timer+Scheduler.SchedulerThread () [0x00000] in <filename unknown>:0
  at System.Threading.Thread.StartInternal () [0x00000] in <filename unknown>:0
[ERROR] FATAL UNHANDLED EXCEPTION: System.NullReferenceException: Object reference not set to an instance of an object
Post by Dean » Mon Apr 06, 2015 9:35 am
In this file /etc/init.d/monoserve find the string
start-stop-daemon -S -c $USER:$GROUP -x $DAEMON -- $ARGS
and add to it: </dev/null >/dev/null 2>&1 &
So it would be:
start-stop-daemon -S -c $USER:$GROUP -x $DAEMON -- $ARGS </dev/null >/dev/null 2>&1 &
mattevansnz
Post by mattevansnz » Wed Apr 22, 2015 10:28 am
Hi All,
I'm having a very similar issue. I have OnlyOffice up and running, but then 'monoserve' seems to crash after very little use. The log seems to reveal...
Error  : Failed to accept connection. Reason: Invalid arguments
Any ideas/help to diagnose this issue would be appreciated. :)
Thanks,
Mat.
mattevansnz
Post by mattevansnz » Wed Apr 22, 2015 12:27 pm
Sorry, should have mentioned the following...
Ubuntu 14.04.2 LTS (trusty)
Docker version 1.6.0, build 4749651
I used the latest docker-compose.yml provided.
Thanks,
Mat.
Post by Dean » Mon Apr 27, 2015 1:04 pm
What are the server capabilties?
mattevansnz
Post by mattevansnz » Thu May 21, 2015 1:58 pm
Not to worry. Issue has been resolved. Thanks anyway.
Ended up upgrading 14.04 kernel to 3.19. This seems to have sorted it all out.
M.
Locked
