What's difference and abilities between editions of OO?
UltraStalker
Post by UltraStalker » Wed Jul 22, 2020 9:06 am
Good day. From the technical manual on your site, I could not figure out the answers to the following questions:
In which versions is the ability to work with OnlyOffice through the API available?
What are the restrictions on working with the API in the Community Edition (if any)?
What are the full technical limitations of the Community Edition?
Thank you in advance.
Re: What's difference and abilities between editions of OO?
Post by Carl » Mon Jul 27, 2020 7:44 am
If you mean the Document Server, here you can find what features are missing in the Community Edition:
https://www.onlyoffice.com/compare-editions.aspx
As for API, there are no particular restrictions besides the ones described on the above page.
