Install onlyoffice in subdirectory
anroba
Post by anroba » Mon Mar 07, 2016 5:43 pm
I have installed Community Server + Document Server with Docker. Everything works OK under primary domain http://www.example.com.
Now, I need offer onlyoffice under subfolder (http://www.example.com/onlyoffice), leving primary domain http://www.example.com free.
I tried to configure vpath in hyperfastcgi <vpath>/onlyoffice</vpath following
https://github.com/ONLYOFFICE/HyperFastCgi
http://www.mono-project.com/docs/web/fastcgi/
, but although I access to onlyoffice with http://www.example.com/onlyoffice, I have errors loading css styles.
I've tried changing location and rewrite in nginx, but KO, too.
Ideas?
Regards.
Re: Install onlyoffice in subdirectory
Post by Dean » Wed Mar 09, 2016 11:29 am
Did you change a <vhost> parameter?
Yoann
Post by Yoann » Wed Mar 09, 2016 3:28 pm
I have the same request.
How can i configure a vhost for HyperFastCgi ?
Thanks for your help,
Yoann.
anroba
Post by anroba » Thu Mar 10, 2016 6:06 pm
My config hyperfastcgi
# cat /etc/hyperfastcgi/
<configuration>
	<server type="HyperFastCgi.ApplicationServers.SimpleApplicationServer">
		<root-dir>/var/www/onlyoffice/WebStudio</root-dir>
	</server>
	<listener type="HyperFastCgi.Listeners.NativeListener">
		<apphost-transport type="HyperFastCgi.Transports.NativeTransport">
			<multithreading>Task</multithreading>
		</apphost-transport>
		<protocol>Unix</protocol>
		<address>//666@/var/run/onlyoffice/onlyoffice.socket</address>
	</listener>
	<apphost type="HyperFastCgi.AppHosts.AspNet.AspNetApplicationHost">
		<log level="Error" write-to-console="false" />
		<add-trailing-slash>false</add-trailing-slash>
	</apphost>
	<web-applications>
		<web-application>
			<vhost>www.example.com</vhost>
			<name>onlyoffice</name>
			<vpath>/onlyoffice</vpath>
			<path>.</path>
		</web-application>
	</web-applications>
</configuration>
I have proved with vhost name in config nginx.
# cat /etc/nginx/sites-enabled/onlyoffice
server {
        listen 80;
        server_name http://www.example.com;
        location / {
but http://www.example.com/onlyoffice shows errors GET .css (error 404).
It doubles the path /onlyoffice/onlyoffice
example.com/onlyoffice/onlyoffice/discbundle/common/javascript/vPRcr6JGwMpxStiIujlOqg2.js?ver=264
example.com/onlyoffice/onlyoffice/discbundle/common/css/TJ43IYJIeg4VN0mKuAYOkQ2.css?ver=264
example.com/onlyoffice/onlyoffice/discbundle/common/css/oD4ITsLqSGZ4x391kk-9QA2.css?ver=264
Any ideas?
Yoann
Post by Yoann » Fri Mar 11, 2016 10:09 am
Thanks for your config.
For me, i don't get any 404 error.
I have a strange behaviour, the css files are empty with only this line :
Copyright (c) Ascensio System SIA 2016. All rights reserved.
http://www.teamlab.com
For this result, i make some modification in my config nginx :
server {
listen 80;
root /var/www/onlyoffice/WebStudio;
location /onlyoffice {
Yoann.
anroba
Post by anroba » Fri Mar 11, 2016 2:21 pm
This is my mistake too
example.com/onlyoffice/onlyoffice/discbundle/common/css/wbY5HHT1XWq4
http://www.onlyoffice.com
Yoann
Post by Yoann » Tue Mar 15, 2016 8:43 am
I think a little help would be really appreciate here :)
How can we configure properly a virtual path ?
Thanks !
Yoann.
Post by Dean » Thu Mar 17, 2016 9:10 am
Our developers are checking the issue. I will contact you as soon as I get any news.
Yoann
Post by Yoann » Fri Mar 18, 2016 7:44 am
Thanks Dean !
Yoann
Post by Dean » Fri Mar 18, 2016 10:39 am
Please try to change the config files:
/var/www/onlyoffice/WebStudio/web.appsettings.config
/var/www/onlyoffice/WebStudio2/web.appsettings.config
Find the setting web.client.bundling and change its value to 'false':
<add key="web.client.bundling" value="false" />
