[SOLVED] Install script fails on Ubuntu 18.04 (with deb)
angenoir
Post by angenoir » Mon May 25, 2020 9:20 am
Hello.
I'm trying to install Community Server (deb version) on Ubuntu 18.04 since 2 days but the install script fails at the very last task, installing Community Server itself, with the error
Package 'onlyoffice-communityserver' has no installation candidate
Setting up onlyoffice-documentserver (5.5.3-39) ...
adduser: Warning: The home directory `/var/www/onlyoffice/documentserver' does not belong to the user you are currently creating.
Adding user www-data to group ds
Generating AllFonts.js, please wait...Done
Generating presentation themes, please wait...Done
Congratulations, the ONLYOFFICE documentserver has been installed successfully!
Processing triggers for libc-bin (2.27-3ubuntu1) ...
Reading package lists...
Building dependency tree...
Reading state information...
Package onlyoffice-communityserver is not available, but is referred to by another package.
This may mean that the package is missing, has been obsoleted, or
is only available from another source
E: Package 'onlyoffice-communityserver' has no installation candidate
I'm using a fresh install of Ubuntu 18.04, with latest updates, on a EC2 instance and I do nothing else than running the install script.
The error happen in the script "install-app.sh", when it runs
apt-get install -yq ${package_sysname}-communityserver
And this is what I have when I look for this package with
apt search communityserver
Sorting... Done
Full Text Search... Done
r7-office-communityserver/squeeze 10.5.2.1063 all
  Community Server is a free open source collaborative system developed to manage documents, projects, customer relationship and email correspondence, all in one place.
I've tried to install this given package (r7-office-communityserver) but it is a Russian version of CS (?!) with no other languages.
... please help! :)
Thanks.
Alexandre
Re: Install script fails on Ubuntu 18.04 (with deb)
Post by Alexandre » Tue May 26, 2020 2:43 pm
Hello angenoir.
We know about this situation and have already fixed it.
As for your installation issue, please clarify, was the installation “clean”? I mean no other apps are installed on the server.
angenoir
Post by angenoir » Wed May 27, 2020 9:43 am
Hello.
Thanks for the reply.
When did you fix this issue?
I just tried again, and, indeed, no more issue.
I guess it was just a bad timing; I would have wait few days, I wouldn't lost a day trying to install it... :?
Well thanks anyway :)
