[Solved] How to change SpellChecker Port
javito
Post by javito » Mon Sep 16, 2019 12:01 am
Hi, i decided to register here cause theres an issue that is driving me cracy and i havent been able to figure it out how to fix it, i have another webserver running on port 8080 on my computer and i need to change the spellchecker port to 8081 for example so both platforms can work in the same computer, i havent found any information on how to do this anywhere so i decided to come here and give it a shoot to see if i finally nail it.
Iv already tried to change it to 8081 on /etc/onlyoffice/documentserver/nginx/includes/http-common.conf (i read that there was suppose to be a onlyoffice only but there isnt, i guess that was in an older version)
upstream spellchecker {
server localhost:8081;
then restarted my linux but still doesnt work, it keeps running on port 8080
Andrew
Re: How to change SpellChecker Port
Post by Andrew » Tue Sep 17, 2019 1:39 pm
1. Please add to /etc/onlyoffice/documentserver/local.json
"SpellChecker": {
                "server": {
                        "port": 8081
2. Edit file /etc/onlyoffice/documentserver/nginx/includes/http-common.conf
and change 8080 to 8081 port
3. Restart Nginx
service nginx restart
4. Restart Document Servers services
supervisorctl restart all
Check it please and notify about the result.
javito
Post by javito » Wed Sep 18, 2019 2:25 am
"SpellChecker": {
                "server": {
                        "port": 8081
3. Restart Nginx
Well i try it at first but it didnt work, because it was missing the , at the end of the last } hehe, once i corrected that it finally worked, iv been doing some research on this topic over the past few days and everything i read said that every nodejs app can set his own port with the "port": command, but since im not too deep into programing, i started trying some variations of ur solution to see why it didnt worked until i notice it was missing the , hehe thank you very much for ur help, im not the only one looking for this over the internet so i hope anyone else looking for this subject can find the answer in here hehe, ill paste the code here with the added ,
"SpellChecker": {
                "server": {
                        "port": 8081
for all of u who are reading this, i inserted the code after the initial { in the local.json file.
ony more question for ya, why is the need to change the port in http-common file if it seems that node ignores it entirely, node only considers the changes in the json file regardless of what i do there, my guess is to have nginx foward the requests to from the port defined in http-common to the node port?
javito
Re: [Solved] How to change SpellChecker Port
Post by javito » Wed Sep 18, 2019 2:42 am
after further testing i realized it cannot be set after the "rabbitmq" cause it gives an error and services wont start, i guess thats because the port has to be defined before the rabbitmq definition since is the one that defines the web address hehe
javito
Post by javito » Wed Sep 18, 2019 11:59 pm
here is a little line i made with sed to add the port to the node app
sed -i "/^{/a \   \"SpellChecker\": {\n           \"server\": {\n              \"port\": PORT\n           }\n     }," /etc/onlyoffice/documentserver/local.json
just replace PORT for the number u want it to be ;)
