undocumented parameter "cluster-mode"
ckippe
Post by ckippe » Fri Mar 26, 2021 1:58 pm
there is a parameter in ubuntu debconf called "onlyoffice/cluster-mode".
onlyoffice-documentserver-ee    onlyoffice/cluster-mode boolean false
Could anybody please explain what is behind the "cluster-mode" as it is not described?
Thanks in advance!
Christian
Re: undocumented parameter "cluster-mode"
Post by Carl » Mon Mar 29, 2021 9:32 am
Hello Christian,
This mode allows adding nodes to the cluster without adding or deleting data in the database.
