Hardware Required to run OnlyOffice
newgenuk
Post by newgenuk » Thu Dec 05, 2019 9:39 am
Hi All,
Can anyone recommend the minimum hardware spec needed to run OnlyOffice?
Thanks.
Andrew
Re: Hardware Required to run OnlyOffice
Post by Andrew » Mon Dec 09, 2019 12:42 pm
Hello newgenuk,
It depends on product, OS and installation type.
for Document Server:
https://helpcenter.onlyoffice.com/serve ... ments.aspx
for Community Edition portal this could be the answer:
