Incorrect formatting of Thai characters
supportb
Post by supportb » Wed Mar 24, 2021 8:52 am
OnlyOffice unable to format some Thai characters correctly e.g.
อั่
Serge
Re: Incorrect formatting of Thai characters
Post by Serge » Thu Mar 25, 2021 9:47 am
The Thai script displays correctly with the FreeSerif font with Document Server 6.2. The font should be installed during the Document Server's setup. If you're not sure where to look for it, please specify the OS where the Document Server is installed and the product's installation type.
supportb
Post by supportb » Mon Apr 05, 2021 8:44 am
still not working. Same crumpled up characters stacked on top of each other.
I am using OnlyOffice on desktop btw.
Serge
Post by Serge » Tue Apr 06, 2021 8:38 am
The desktop editors use the fonts available on your OS. So your system is, most likely, missing a font that properly supports Thai characters. You can look for one that does and install it using this guide: https://helpcenter.onlyoffice.com/ONLYO ... fonts.aspx
