The font problem
minio
The font problem
Post by minio » Wed Dec 30, 2020 2:25 am
hello,According to the requirements of the document, I imported some of my own fonts, but when I used the original font, the font in the form of box would appear directly, which was the case of disorderly code, resulting in the font could not be displayed at all.
Here is a screenshot of my problem。
字体.zip
(33.59 KiB) Downloaded 12 times
Serge
Re: The font problem
Post by Serge » Wed Dec 30, 2020 1:24 pm
Could you send us the custom font you used? Also, please specify your Document Server's version and whether or not this only happens in text boxes.
minio
Post by minio » Thu Dec 31, 2020 2:25 am
Thank you. I modified the font into Chinese with the plugin,But I don't think it will affect, but after import, those built-in characters will appear incompatible, disorderly code situation,Not just in the text box, but everywhere else. The following is the same for displaying fonts in other placesVersion 5.4.2.46 of the document server。Is it convenient to provide a mailbox to send fonts? The attachment here always shows too big.thank you
1fonts.zip
(905 Bytes) Downloaded 8 times
