Editing problems
minio
Editing problems
Post by minio » Tue Dec 29, 2020 6:30 am
Hello, every time an editor encounters numbers and words, the numbers wrap themselves at the end when they are very long. I have correctly set in Word to allow Western words to wrap themselves in the middle of words, but in onlyOffice this is invalid, and the text is still displayed at a wide distance, resulting in incorrect document format.
Below I give a screenshot of the link image
文字和数字的问题.zip
(69.17 KiB) Downloaded 17 times
User avatar
quickhot
Re: Editing problems
Post by quickhot » Wed Dec 30, 2020 6:58 am
This is not a problem, the numbers be traded as one word.
So you will find it still there if you are using wps.
http://oftest.wkind.cn/imgs/no_problem.png
:D :lol:
minio
Post by minio » Thu Dec 31, 2020 1:27 am
But WPS can be adjusted, WPS can be set in Western languages, but I can set this in Word or WPS, and the onlyOffice will only display a wider distance
Serge
Post by Serge » Thu Jan 21, 2021 8:50 am
We've reproduced the issue and it's now registrered as a bug. It will be fixed in a future update. Thanks for the feedback!
