How long should a "key" be available?
polx
Post by polx » Fri Sep 27, 2019 8:40 am
Hello OO community,
I'm enjoying the DocumentServer and have been tuning the "key" parameter of the editor's document config so that users of our assessment system recover the work they do even if they have to change machine: the key is made of the filename and the user-name. This is a nifty usage of the collaborative feature!
It seems even to be so, that coming back with the same key a few days later still gets you everything that was there.
But how can I estimate if the content will stay long and safe?
I think that this is not documented anywhere because most people use external storage engines.
My suggestion is that this answer could be made into the parameter's description.
thanks in advance.
Paul
Andrew
Re: How long should a "key" be available?
Post by Andrew » Tue Oct 01, 2019 1:58 pm
Is it stand-alone Document Server? Could you please specify which components and versions do you use?
polx
Post by polx » Tue Oct 01, 2019 3:06 pm
Thanks,
DocumentServer standalone (on Debian Linux) version 5.4.0-21.
We run without a community server.
From what a colleague looked at in the source, it seems to be that deletion does not happen per default in the production configuration. Is that true?
thanks
paul
