SpreadSheet Editor in Embedded viewers mode : Horizontal Scroll bar is above sheets names
olrondeau
Post by olrondeau » Wed Sep 04, 2019 3:25 pm
On your online version, when I have multiples sheets I have a display trouble with horizontal scroll bar.
Scroll bar is positionned above sheets names.
This problem appears only in Embedded viewers mode.
A print screen in attachment.
Scroll bar horizontal above sheets names in Embedded Viewers mode.png (88.72 KiB) Viewed 562 times
Re: SpreadSheet Editor in Embedded viewers mode : Horizontal Scroll bar is above sheets names
Post by Carl » Thu Sep 12, 2019 7:35 am
Hello.
Are you using a Cloud ONLYOFFICE solution? Please describe the issue on this forum: https://cloud.onlyoffice.org/
olrondeau
Post by olrondeau » Thu Sep 12, 2019 9:21 am
I do reference of Cloud OnlyOffice to simplify display problem reproduction.
You have the same problem with all version of Documents in Embedded viewers mode.
Andrew
Post by Andrew » Thu Sep 12, 2019 10:44 am
Hello olrondeau,
Thank you for reporting this issue with embedded viewers mode, we will fix it in future ONLYOFFICE releases.
