Bullet symbol is changed when saving from document editor
djk81
Post by djk81 » Fri Aug 16, 2019 1:41 am
In Dcoument server. (We are using self-hosted)
User edit some document with bullets.
The document editor replaced symbols on it.
you can see attached screen shot.
is there any solution fix this? or can i add custom bullet symbol?
thanks
Re: Bullet symbol is changed when saving from document editor
Post by Maxim » Fri Aug 16, 2019 8:41 am
Hello djk81!
Can you attach a file example with this bullet symbol for us to analyze this case?.
djk81
Post by djk81 » Tue Jan 07, 2020 9:16 am
Here is that file.
( And I also replied by email few month ago to CS center about this issue. )
circle_bullet_symbol.zip
(18.02 KiB) Downloaded 27 times
