I have an issue when an user or two are editing a word document. After hours of works, there are this logs:
[2018-02-25 22:31:24.228] [ERROR] nodeJS - sendServerRequest error: ;url = https://myserverdomain.eu/callbackup.ph ... cc99&;data = {"key":"43bff57de9472f30","status":6,"url":"https://serverXXXX.net/cache/files/43bf ... ","changes":[{"created":"2018-02-25 21:26:25","user":{"id":"65f3efa73dd4079a4ee676874abdf","name":"Nat"}},{"created":"2018-02-25 21:27:42","user":{"id":"fc61ea1fe07103777aafe19fd8f1","n
etc
With a lot of history records and at the end:
Error: Error response: statusCode:400 ;body:
<!DOCTYPE HTML PUBLIC "-//IETF//DTD HTML 2.0//EN">
<html><head>
<title>400 Bad Request</title>
</head><body>
<h1>Bad Request</h1>
<p>Your browser sent a request that this server could not understand.<br />
Size of a request header field exceeds server limit.</p>
<hr>
<address>Apache/2.4.10 (Debian) Server at myserverdomain.eu Port 443</address>
</body></html>
at Request._callback (/var/www/onlyoffice/documentserver/server/Common/sources/utils.js:260:18)
at Request.self.callback (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:188:22)
at emitTwo (events.js:106:13)
at Request.<anonymous> (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:1171:10)
at emitOne (events.js:96:13)
at IncomingMessage.<anonymous> (/var/www/onlyoffice/documentserver/server/Common/node_modules/request/request.js:1091:12)
at IncomingMessage.g (events.js:292:16)
at emitNone (events.js:91:20)
I've upgrade my server apache configuration with more limit
LimitRequestFieldSize 16380
But the thing is, Is there any configuration to don't save all the history of the document, or reset it? Because every callbackup send all the history.
If an user is working for hours in a document this history could be so huge.
Callback history. How to clean up?
Re: Callback history. How to clean up?
Have you found a way how to do that?Is there any configuration to don't save all the history of the document, or reset it? Because every callbackup send all the history.
No, not yet
Hello dataprius,
Do you use JWT in your example? Please change it to JWT in body using this info from API.
