Forum rules
0
23177
21 December 2020
0
31
17 April 2024
1
29
17 April 2024
7
164
17 April 2024
WordCounter plugin
0
27
17 April 2024
Font selector - should filter the whole font name, not just the begining of the font name
2
59
17 April 2024
30
2174
17 April 2024
To-big-to-fit tables sould be more easy to modify
5
122
17 April 2024
Conflict between forced save and automatic save
3
81
17 April 2024
Updating containers?
3
92
17 April 2024
2
53
17 April 2024
0
30
17 April 2024
Run docs server without nextcloud
3
66
17 April 2024
Simplified Chinese translation optimization suggestions
4
97
17 April 2024
2
61
17 April 2024
Sleep/wake-up - OO closes without any information & file are not save
21
763
17 April 2024
Running OnlyOffice with Docker-Compose - WOPI - Connection refused while connecting to upstream
37
6226
16 April 2024
0
42
16 April 2024
Bullet list are acting weird when changing font size
0
59
15 April 2024
1
53
16 April 2024
Endnotes disappear after conversion from Footnotes
10
138
16 April 2024
Why, when copy-pasting a shape a new line is inserted?
1
51
16 April 2024
Docker document server and nextcloud : document could not be saved
3
94
16 April 2024
How to modify the default font of docs
3
173
16 April 2024
OO Docs-enterprise: Connectivity Issues with OnlyOffice and Nextcloud via HTTPS and Custom Domain
2
103
16 April 2024
Is it possible to access Shared Drives in our Google Workspace?
6
159
16 April 2024
0
36
16 April 2024
How to getTable in Presentation?
2
82
16 April 2024
App does not open files
0
43
15 April 2024
In the Community version I can't add an external link to a folder, there is an option to grant external user access for files only. Really need external link access for folders - it doesn't work! Also adding multiple external links doesn't work
4
379
15 April 2024
