ONLYOFFICE Docker-container
ONLYOFFICE Open Source Version news
DevvynAtOTVTech
Re: ONLYOFFICE Docker-container
Post by DevvynAtOTVTech » Fri Feb 27, 2015 9:13 pm
I absolutely love this!
An ONLYOFFICE container I can quickly, easily, and reliably deploy has been a valuable tool in my developer's toolbox. I've deployed this Docker image on our internal servers as a sandbox environment for learning or demonstration, and also on my development workstation. While building an application that uses the ONLYOFFICE API, I used Docker to run server instances on a whim, for integration testing.
I appreciate the convenience and I feel grateful. I could go on and on about all the positive ramifications… I hope it will suffice to merely say, thank you for your efforts in this area! :D
phs
Post by phs » Fri Apr 03, 2015 11:30 pm
Onlyoffice is looking really interesting, and thanks to the dev team for making it possible. We've been testing the Docker container and have found the following results:
1) It is possible to access the running onlyoffice container via HTTPS, which is great.
2) Can't get SMTP to work for the registration email, or the email test function in the SMTP setup page. This is after going through every email setting we could find. Couldn't find any relevant errors, either, but maybe we're not looking in the right place.
3) The biggest issue: Probably we're not understanding something very simple, but after configuring the onlyoffice container instance via the web interface, or after configuring any of the container OS settings, all changes or user data is lost once the container is stopped. Is there some reasonable way to make all of the data in the container persistent? Obviously it's not possible to use this in production if the data is lost every time the container is stopped. Again, probably missing something obvious at our end.
4) There are several volumes created in the docker file, but other than the /var/www/onlyoffice/Data volume, which we're using to access the SSL certificates, we're not sure what the intended purpose of the other two volumes is.
5) From what we're able to test so far, most other things seem to be basically working.
Any information on the points listed above would be much appreciated and thanks for the great work!
phs
Post by Dean » Tue Apr 21, 2015 6:18 am
We shall check if it works or not.
phs wrote: 3) The biggest issue: Probably we're not understanding something very simple, but after configuring the onlyoffice container instance via the web interface, or after configuring any of the container OS settings, all changes or user data is lost once the container is stopped. Is there some reasonable way to make all of the data in the container persistent? Obviously it's not possible to use this in production if the data is lost every time the container is stopped. Again, probably missing something obvious at our end.
3) It is necessary to START the container every time, not to RUN it. Use the command '(sudo) docker staro {container id}'
phs wrote: 4) There are several volumes created in the docker file, but other than the /var/www/onlyoffice/Data volume, which we're using to access the SSL certificates, we're not sure what the intended purpose of the other two volumes is.
4) VOLUME ["/var/log/onlyoffice"] - The logs of ONLYOFFICE
VOLUME ["/var/www/onlyoffice/Data"] - uploaded portal data (docs, for instance)
VOLUME ["/var/lib/mysql"] - database
In other words, if set the volume up (http://docs.docker.com/userguide/dockervolumes/ you will always be able to access the DB and the portal data.
th0mas
Post by th0mas » Tue Apr 21, 2015 9:55 pm
I've started an instance with CommunityServer and DocServer and both 8.5 and 3.0, but if I want to create an Document a message appears like "Access to the path "/var/www/onlyoffice/Data/Products/Files/0" is denied." If I create the folder, the message ask in the next step for a further folder. Is there an special user I have to chown? The directory works already for SSL!
th0mas
Post by th0mas » Tue Apr 21, 2015 10:17 pm
Okay, the problem was no wirte-access to folder but there still one problem. If I create a user and want wo upload a picture the message appears "The socket has been shut down". Whats wrong?
th0mas
Post by th0mas » Tue Apr 21, 2015 11:16 pm
Same problem as last version:
[2015-04-21 23:13:18] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-21 23:13:18] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
I have do absolutly nothing in config or something. I clicked CRM and the service isnt available anymore :/
th0mas
Post by th0mas » Thu Apr 23, 2015 11:56 am
[2015-04-23 11:47:29] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:47:29] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:47:30] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:47:30] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:47:33] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:47:33] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:47:42] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:47:42] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:47:42] Error  : Failed to process connection.
[2015-04-23 11:47:42] Error  : Object reference not set to an instance of an object
[2015-04-23 11:47:42] Error  :   at (wrapper unknown) System.Threading.Monitor:FastMonitorEnterV4 (object,bool&)
[2015-04-23 11:47:42] Error  :   at Mono.FastCgi.Connection.get_UnfinishedRequests () [0x00000] in <filename unknown>:0
[2015-04-23 11:47:42] Error  :   at Mono.FastCgi.Connection.Run () [0x00000] in <filename unknown>:0
[2015-04-23 11:47:42] Error  :   at Mono.WebServer.FastCgi.ConnectionProxy.Run () [0x00000] in <filename unknown>:0
[2015-04-23 11:47:42] Error  :   at Mono.WebServer.FastCgi.GenericServer`1[Mono.WebServer.FastCgi.ConnectionProxy].OnAccept (IAsyncResult ares) [0x00000] in <filename unknown>:0
[2015-04-23 11:47:43] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:47:43] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:47:43] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
  at System.Threading.ExecutionContext.CreateLogicalCallContext (Boolean createEmpty) [0x00000] in <filename unknown>:0
  at System.Runtime.Remoting.RemotingServices.SerializeCallData (System.Object obj) [0x00000] in <filename unknown>:0
  at (wrapper xdomain-invoke) Mono.WebServer.FastCgi.ApplicationHost:ProcessRequest (Mono.WebServer.FastCgi.Responder)
  at (wrapper remoting-invoke-with-check) Mono.WebServer.FastCgi.ApplicationHost:ProcessRequest (Mono.WebServer.FastCgi.Responder)
  at Mono.WebServer.FastCgi.Responder.Process () [0x00000] in <filename unknown>:0
[2015-04-23 11:48:32] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:48:32] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:49:58] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:49:58] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:49:58] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:51:17] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:51:17] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:51:17] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:51:18] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:51:18] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:51:18] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:51:36] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:51:36] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:51:36] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:01] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:01] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:01] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:13] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:13] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:13] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:21] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:21] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:21] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:28] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:28] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:28] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:30] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:30] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:30] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:33] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:33] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:33] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:36] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:36] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:36] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:40] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:40] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:40] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:49] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:49] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:49] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:50] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:50] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:50] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:52:51] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:52:51] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:52:51] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:53:18] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:53:18] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:53:18] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:53:52] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:53:52] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
[2015-04-23 11:53:52] Error  : ERROR PROCESSING REQUEST: System.NullReferenceException: Object reference not set to an instance of an object
[2015-04-23 11:56:03] Warning: Duplicate name, SERVER_NAME, encountered. Overwriting existing value.
[2015-04-23 11:56:03] Warning: Duplicate name, SCRIPT_FILENAME, encountered. Overwriting existing value.
Post by Dean » Fri Apr 24, 2015 12:38 pm
please revew this topic: viewtopic.php?f=37&t=5845
phs
Post by phs » Fri Apr 24, 2015 1:14 pm
Dean - thanks so much for your help -- your points make sense. We hope to do further testing next week and will report back with anything that might be helpful to others.
This is an excellent project!
phs
