HTTPS-Port on snap
IIS, Apache
BlackSilicon
HTTPS-Port on snap
Post by BlackSilicon » Sat Dec 07, 2019 12:55 pm
is it possible to change the https port onlyoffice is listening to within a snap environment? Sadly only the change of http port ist documented.
Kind regards
Florian
Re: HTTPS-Port on snap
Post by Carl » Mon Dec 09, 2019 12:48 pm
Hello Florian,
Please follow the guide to switch Document Server snap to https:
https://github.com/ONLYOFFICE/snap-documentserver
You don't need to indicate the https port, just install the certificate.
