IIS configuration for OnlyOffice
IIS, Apache
Locked
tobi
Post by tobi » Tue Sep 30, 2014 10:10 am
After installation of OnlyOffice on a Windows 2012 R2 server I found two new sites for OnlyOffice in IIS manager. By default it seems OnlyOffice configures itself during setup to the computer name, so the login site is displayed when I open the dns server name in the webbrowser. But I want to use this for displaying the default home page.
So how is it possible to "move" OnlyOffice to a IIS virtual directory, e.g. <Domain>/OnlyOffice or to a subdomain, e.g. onlyoffice.<Domain> ?
Re: IIS configuration for OnlyOffice
Post by Dean » Fri Oct 03, 2014 1:34 pm
This feature is unfortunately unavailable. We'll add your suggestion to the list for further consideration.
You may also send your suggestion to our feedback page (http://feedback.onlyoffice.com/). You suggestion will be considered by all means.
Locked
