Admin account activation
frk89
Post by frk89 » Tue Dec 01, 2015 6:21 am
Can this be a reason that I am running onlyoffice behind proxy server thats why my admin account is not getting activated??
If yes how to overcome that please tell.
If no them why i am not able to send either test mails or admin activation mail.
port 9871 is open in my system.
Re: Admin account activation
Post by Dean » Wed Dec 02, 2015 11:44 am
What are the SMTP-settings that you use?
Is port 25 free & open?
frk89
Post by frk89 » Thu Dec 03, 2015 9:05 am
Hi
Smtp settings are OK(I guess) since smtp test mails are working.But didnt got any activation mail.Though I overcome that by manually updating activation_status=1 in database ;) .so no more pop pups for activating email ID.
But when tried to configure e-mail account got following errors in web.api.log
2015-12-03 13:09:16,441 ERROR [Threadpool worker] ASC.Api - method error: http://10.208.66.142/api/2.0/mail/accou ... ?__=280615 - Server error
System.Exception: Invalid certificate received from server.
at ASC.Api.Mail.MailApi.CreateAccount (System.String name, System.String email, System.String account, System.String password, Int32 port, System.String server, System.String smtp_account, System.String smtp_password, Int32 smtp_port, System.String smtp_server, Boolean smtp_auth, Boolean imap, Boolean restrict, EncryptionType incoming_encryption_type, EncryptionType outcoming_encryption_type, SaslMechanism auth_type_in, SaslMechanism auth_type_smtp) [0x00000] in <filename unknown>:0
If this is certificate related error then pls tell procedure to install ssl certificates for only-office.
Post by Dean » Thu Dec 03, 2015 1:23 pm
Could you please send us a logfile svcNotify?
