Strange behavior while document opening [solved]
Postby AndrewG » Fri May 26, 2017 8:06 am
Hi OnlyOffice team!
Could you please have a look and suggest what could be a reason for the following error:
[2017-05-26 07:34:37.282] [ERROR] nodeJS - stdout (id=ds1-db0-c03d-5927d95bc916c41443959061):[0526/072940:ERROR:browser_main_loop.cc(219)] Running without the SUID sandbox! See https://chromium.googlesource.com/chromium/src/+/master/docs/linux_suid_sandbox_development.md for more information on developing with the sandbox on.
Xlib:  extension "RANDR" missing on display ":14".
[2017-05-26 07:34:37.283] [ERROR] nodeJS - stderr (id=ds1-db0-c03d-5927d95bc916c41443959061):
[2017-05-26 07:34:37.283] [ERROR] nodeJS - ExitCode (code=0;signal=SIGTERM;error:-83;id=ds1-db0-c03d-5927d95bc916c41443959061)
This happens with documents when you try to open them with Document Editor.
Thank you!
Best regards,
Andrew
User avatar
AndrewG
Re: Strange error while document opening
Postby AndrewG » Sat May 27, 2017 5:32 am
...Probably I need to add that the error appear in the following log: ..../DocumentServer/logs/documentserver/converter/out.log
Any thoughts are highly appreciated!
Thanks!
Best regards,
Andrew
User avatar
AndrewG
Postby Maxim » Mon May 29, 2017 10:32 am
Hello AndrewG!
Specify please what file did you try to open? HTML?
Postby AndrewG » Tue May 30, 2017 9:33 am
Hi Maxim,
thank you for your question! Mentioning "HTML" let us double-check Storage Service access implementation and we have found flows in our implementation!
So issue is on our side! Will be fixing it! Thanks again!
Best regards,
Andrew
User avatar
AndrewG
Re: Strange behavior while document opening [solved]
Postby Maxim » Tue May 30, 2017 11:58 am
Hello AndrewG!
You're always welcome!
