Controlling co-edit mode
Postby stuartcampbell » Tue May 23, 2017 1:15 am
Hi team,
Is there a way to configure the default co-edit mode? I'd like to force the default to be 'strict' rather than 'fast' - can I do that via the configuration?
Thanks
stuartcampbell
Re: Controlling co-edit mode
Postby Maxim » Tue May 23, 2017 8:23 am
Hello stuartcampbell!
You need to add to config parameter "autosave": false in customization section
"editorConfig": {
   "customization": {
      "autosave": false
But it works in case when there is no in browser's localstorage data about previous work in Onlyoffice. If a user worked before in Onlyoffice in fast mode this setting will be saved in localstorage and this parameter is more privilege
