Quotation Making Module
Postby kksaeed » Mon May 22, 2017 10:40 am
Any body worked on quote module or add on in onlyoffice.
As you know at the moment you can create invoice within CRM but cannot create quotation/proposal. I want a quote module in which you first create a Quote and later convert to invoice.
Please help.
Re: Quotation Making Module
Postby Maxim » Tue May 23, 2017 11:15 am
Hello kksaeed!
We plan to change invoice in future releases. Thank you for your idea!
