Need Information about the API
Postby wsit_anik » Tue May 16, 2017 5:06 am
I want to implement OnlyOffice on a website. But, I have some questions regarding integration and API before buying.
* Is it possible to programatically add footer text for a page?
* Is it possible to determine the last page?
* Is it possible to add new custom menu on the editor which shows some text?
* Is it possible to drag and drop text content on the editor?
Are these things are doable with the existing API? Or I need to write custom code? If so, how customizable the editor would be?
wsit_anik
Re: Need Information about the API
Postby Maxim » Tue May 16, 2017 6:15 am
Hello wsit_anik!
Have you visited API?
Postby wsit_anik » Wed May 17, 2017 8:03 am
I read the API. But, they could not answer all of my questions. @Maxim
wsit_anik
Postby Maxim » Wed May 17, 2017 8:43 am
Hello wsit_anik!
No.
Postby robertotomas » Fri Sep 29, 2017 3:09 pm
why do you say these are not possible? The helloworld plugin shows an example of adding text to a document. Surely it could be made a footer.
robertotomas
Postby Maxim » Mon Oct 02, 2017 7:18 am
Hello robertotomas!
I meant that using API it's not possible, but using plugin i suppose it's possible..
