Document Server showMessage() method
Postby AndrewG » Sun May 14, 2017 1:48 am
Hi everyone,
according to the documentation https://api.onlyoffice.com/editors/methods#showMessage docEditor.showMessage(title, message, type) method should "Display dialog with the message."
Where "type" - defines the dialog type. Can be: info, warning, error. But this parameter is absolutely disregarded, and the dialog shown as tooltip but not as expected dialog what is the main issue.
(1) So it shows message in the format:
showMessage() message as is
(2) But instead the message in the following format is expected to be shown:
showMessage() message expected
The question: is it possible to generate dialogs like the expected one (2)?
Thanks!
Best regards,
Andrew
User avatar
AndrewG
Re: Document Server showMessage() method
Postby Maxim » Mon May 15, 2017 12:25 pm
Hello AndrewG!
Thank you for the information you posted.
The documentation will be changed to correct content.
Parameter "type" will be shown as tooltip.
Postby AndrewG » Mon May 15, 2017 2:35 pm
Thanks for the answer, but is it possible to show dialog NOT like a tooltip?
Best regards,
Andrew
User avatar
AndrewG
Postby Maxim » Tue May 16, 2017 6:26 am
Hello AndrewG!
Unfortunately there is no way for now.
