update user's userName
Postby pciavald » Wed Jan 11, 2017 3:05 pm
is it possible to update a user's userName ? By default onlyoffice takes what's before the @ of the email address, for instance contact for contact@enterprise.com which makes it not very useful.
I thought the PUT api/2.0/people/{userid} would allow it but it doesn't seem to.
thank you
pciavald
Re: update user's userName
Postby Maxim » Thu Jan 12, 2017 10:03 am
Hello pciavald!
I think it's not possible and more of it i'd say you should use email and user id only. You don't need to use userName.
