Is it possible to setup mail merge options programmatically?
Postby sgaluza » Thu Dec 29, 2016 7:27 pm
sgaluza
Re: Is it possible to setup mail merge options programmatica
Postby sgaluza » Sat Dec 31, 2016 6:34 am
I found fileChoiceUrl option in the editor configuration, but can't figure out how to use it. Can you please advice?
sgaluza
