API Request - Times Filter
Postby adamg » Mon Sep 19, 2016 4:04 am
An API request has been made and i need to know how to filter the request for today only.
https://api.onlyoffice.com/portals/meth ... ime/filter
The above seems to have create and end date of the job. However nothing for the time itself.
Instead of a large amount of values:
The results im getting contain everything :(
Array
[count] => 1000
[total] => 5228
[status] => 0
[statusCode] => 200
[response] => Array
adamg
Re: API Request - Times Filter
Postby Eugenie » Tue Sep 20, 2016 1:41 pm
https://*.onlyoffice.com/api/2.0/projec ... %3A00%3A00
Instead of * alias, instead of 2016-09-20 you need to set the date you need.
You can enter your portal, set the filter as you need and in the tab "Net" you can see the request, which is sent to the server and use it then.
Eugenie
