How to activate user using API
Postby lmenaria » Thu Jun 16, 2016 11:00 am
I have created a user using People user but unable to activate it using API, please let me know how it can be possible? I don't want to send activation mail to users.
Thanks
laxmilal
lmenaria
Re: How to activate user using API
Postby Dean » Thu Jun 16, 2016 12:30 pm
User cannot be activated from API, only by performing the following SQL-request:
UPDATE core_user SET activation_status = 1 WHERE id = "USER_ID";
Postby lmenaria » Fri Jun 17, 2016 7:47 am
Thanks
lmenaria
Postby naboki » Tue Oct 11, 2016 2:34 pm
after changing infos in the database, it takes some time to be visible.
How can we force the refresh?
naboki
Postby Eugenie » Mon Oct 17, 2016 3:30 pm
To accelerate the cache process, please do the following:
UPDATE core_user SET activation_status = 1, last_modified = DATE_ADD(now(), interval 5 minute) WHERE id = "USER_ID"
Eugenie
