Adding custom Text to the editor
Postby shyam » Fri May 27, 2016 11:04 am
Is there a way for me to add custom text into the editor using java script. We are looking for a drag and drop for outside text. Is that supported?
shyam
Re: Adding custom Text to the editor
Postby Dean » Fri May 27, 2016 11:14 am
Currently not, as our Editors do not have an API.
Postby shyam » Sat May 28, 2016 2:01 pm
Thanks for your reply.
shyam
Postby motiap » Mon Aug 29, 2016 11:05 am
It is really good to know about only office document builder release http://helpcenter.onlyoffice.com/develo ... index.aspx
I am not sure whether it would be really helpful to us to achieve this : "insert text in document editor by drag and drop or double click on text outside the editor". If we can do this, we really like to integrate only office document editor in our application.
motiap
Postby Eugenie » Mon Aug 29, 2016 1:21 pm
Unfortunately it is not possible at the moment.
It will be possible in one of the next version, that will be a version with plugins and you will be able to do what you need.
Eugenie
