Unknown error when loading document editor.
Postby laruladh » Fri Feb 19, 2016 11:17 am
I have the latest version of the document server running on a Ubuntu 14.04 box. Inside my web app I have the following configured:
<div id="placeholder"></div>
<script type="text/javascript" src="http://onlyoffice.myserver.local/OfficeWeb/apps/api/documents/api.js"></script>
   <script type="text/javascript">
      $( document ).ready(function() {
       var docEditor = new DocsAPI.DocEditor('placeholder', {
          height: '1000px',
          documentType: 'text',
          document: {
           fileType: 'docx',
           key: 'Khirz6zTPdfd7',
           title: 'Example Document Title.docx',
           url: 'https://demo.myserver.local/memo.docx',
          editorConfig: {
   </script>
However when I load the page I get a popup dialog "Unknown error" (see attached). And a 502 Bad Gateway error in the browser console:
Synchronous XMLHttpRequest on the main thread is deprecated because of its detrimental effects to the end user's experience. For more help, check https://xhr.spec.whatwg.org/.
'CanvasRenderingContext2D.webkitImageSmoothingEnabled' is deprecated. Please use 'CanvasRenderingContext2D.imageSmoothingEnabled' instead.
POST http://onlyoffice.myserver.local/CanvasService.ashx 502 (Bad Gateway)
I'm a bit lost as to what exactly is going on so would appreciate any assistance on this. Thanks in advance.
Unknow error dialog
laruladh
Re: Unknown error when loading document editor.
Postby Dean » Thu Feb 25, 2016 10:37 am
Could you please specify the exact version of Document Server you use?
