[SOLVED] Can't make PHP integration example work.
Postby dandanielw » Wed Jan 13, 2016 7:42 pm
Hi, I've been trying for some days already to make the PHP integration example work without success yet.
I need to get this working in a few days so I request your help.
First of all I describe my current setup to contextualize.
I'm working on an ubuntu linux
➜  ~  uname -a
Linux daniel 3.19.0-33-generic #38~14.04.1-Ubuntu SMP Fri Nov 6 18:17:28 UTC 2015 x86_64 x86_64 x86_64 GNU/Linux
I installed the OnlyOffice through docker like this:
sudo docker run -i -t -d -p 880:80 -p 4443:443 --name onlyoffice \
    -v /opt/onlyoffice/Logs:/var/log/onlyoffice  \
    -v /opt/onlyoffice/Data:/var/www/onlyoffice/Data  onlyoffice/documentserver
I downloaded the integration example from http://api.onlyoffice.com/app_data/PHP%20Example.zip
And I setup the the config.php just like it's suggested in the reply for this post http://dev.onlyoffice.org/viewtopic.php?f=9&t=5740
This is how my config file looks like (only the parts I modified, the other settings are left as they came from the example:
define('WEB_ROOT_URL', 'http://localhost:8080');
$GLOBALS['STORAGE_PATH'] = "archivos";
$GLOBALS['DOC_SERV_STORAGE_URL'] = "http://172.17.0.1:880/FileUploader.ashx";
$GLOBALS['DOC_SERV_CONVERTER_URL'] = "http://172.17.0.1:880/ConvertService.ashx";
$GLOBALS['DOC_SERV_API_URL'] = "http://172.17.0.1:880/OfficeWeb/apps/api/documents/api.js";
$GLOBALS['DOC_SERV_PRELOADER_URL'] = "http://172.17.0.1:880/OfficeWeb/apps/api/documents/cache-scripts.html";
Where
localhost:8080 is the socket for the webserver that will serve and integrate the onlyoffice service
and
172.17.0.1:880 is the socket of the docker container which is actually the onlyoffice server.
So this is what happens:
When I enter http://localhost:8080 I can visuallize correctly the index.html where I see the links for the Sample doc, spreadsheet and presentation, together with the upload option.
When I upload a file, the file is uploaded correctly to the localhost:8080 server as I can see it in the designated folder, and the UI says everything is ok. and the response to the webeditor-ajax.php confirms it
{"filename":"uvq.docx","status":"success"}
now, if I want to open a file for viewing or editing comes the problem.
From the success upload modal windows I click on the edit button and it tries to open the following URL in a new windows:
http://localhost:8080/doceditor.php?fileID=uvq.docx
but I get 2 alert windows (after waiting some long seconds) :
The file cannot be accessed right now
and
Download failed. Press OK to return to document list.
Almost the same thing happens when I try to open a Sample file, but I only the the second message ( Download failed ) .
Can someone give me a hand with this? I really need to get this working.
Thanks a lot.
SOLUTION UPDATE
I noticed that the problem was not the server itself but the file_get_contents(...) function in combination with the http server.
I noticed the function was throwing a Warning "failed to open stream: HTTP request failed!" so after a few unsuccessful workarounds I wondered if php's built in server was causing the problem and it actually that was it. Set up a http server instead of using php -s localhost:8080 the it's solved.
Conclusion: BEWARE of PHP's build-in server.
dandanielw
