Document Data with editor.asc_nativeGetFile()
Postby ibrhm » Fri Nov 06, 2015 12:23 pm
I see this encoded string data when I call editor.asc_nativeGetFile() in the javascript api in the word editor frame.
And I noticed it is also used inside the editor's ".bin" file on the server.
If I post it to my own application server, will i be able to decode it into a word file data myself? It looks like a base64 string.. But i couldn'r really decode it..
If i there is a way to get the word file from that encoded string, it would help me a lot..
ibrhm
Re: Document Data with editor.asc_nativeGetFile()
Postby AnaMih » Mon Nov 09, 2015 1:42 pm
I regret to inform you that there is no way to get the file from that string.
User avatar
