How can i use OnlyOffice API?
Postby YoMismoResidente » Wed Jun 24, 2015 5:51 pm
There's no many information that how to use the api, i am new and i have a project on asp. net using MVC C#, i want to integrate onlyoffice but i dont understand how to embedded to m y project. If some one please can help me or some one have already did it.
YoMismoResidente
Re: How can i use OnlyOffice API?
Postby Dean » Fri Jun 26, 2015 8:32 am
You need to review the documentation for the API of ONLYOFFICE: http://api.onlyoffice.com/editors/basic. Also by that link you may find 2 examples on C#, which can help you to start using our API.
