VOIP integration
VOIP integration
Postby brix » Thu Mar 26, 2015 6:50 pm
I was looking the API documentation and noticed the voip settings under crm. What is this for? This is probably disabled in the linux version, but is it possible to know a little more about this option and how does it integrate voip into onlyoffice?
Is it going to be available in the self-hosted linux version?
We want to somehow integrate voip call (contacts, history and linking together contacts with calls) into onlyoffice.
Any thoughts on this?
Thank you very much!
brix
Re: VOIP integration
Postby Dean » Wed May 13, 2015 9:06 am
The integration method itself is described here: http://api.onlyoffice.com/portals/metho ... /voip/call
The IP calls functionality is on the test stage now.
