NEW API PHP sample Error
Postby johnsujith » Thu Mar 05, 2015 3:08 pm
I am using new PHP API sample ,but its bounce with error ,I have enclosed the screen shot
PHP API Error
johnsujith
Re: NEW API PHP sample Error
Postby Dean » Tue Apr 28, 2015 12:37 pm
1. Download the example from: http://api.onlyoffice.com/editors/demopreview
2. Unpack it on C:\\
3. In IIS turn the site on with specifying the folder with example on C:\\
You can change the port if necessary. Port is 80 by default.
4. Change the C:\OnlineEditorsExamplePHP\config.php file as follows:
1) define('WEB_ROOT_URL', 'http://localhost:8080'); this string
specifies the location for the example to work eith and the port.
2) $GLOBALS['STORAGE_PATH'] = "folder"; this is the location path.
The folder has to be created inside the example folder. Like this:
C:\OnlineEditorsExamplePHP\downloaded ; Files will be saved to this
location only.
3) insert the computer name or the ip-address.
$GLOBALS['DOC_SERV_STORAGE_URL'] = "http://name/FileUploader.ashx";
$GLOBALS['DOC_SERV_CONVERTER_URL'] = "http://name/ConvertService.ashx";
$GLOBALS['DOC_SERV_API_URL'] =
"http://name/OfficeWeb/apps/api/documents/api.js";
$GLOBALS['DOC_SERV_PRELOADER_URL'] =
"http://name/OfficeWeb/apps/api/documents/cache-scripts.html";
