Does not save changes to file
Postby PelleH » Tue Nov 06, 2018 10:51 pm
we are trying to configure a Onlyoffice Community edition server and PHP code on another web server. We want to open a document, edit it and have it saved on the web server.
We have tried with example script produced by Onlyoffice, https://api.onlyoffice.com/editors/example/php.
Our installation can create, delete, open, coediting documents but it cannot save the text to the file after edited. Do you have some experts that we can hire to solve this annoying problem?
We get the error code "The file version has been changed. The page will be reloaded". It may be problem with key.
/Pelle H
PelleH
Re: Does not save changes to file
Postby Carl » Wed Nov 07, 2018 7:09 am
Postby PelleH » Fri Nov 09, 2018 10:14 am
Thanks, but how do I generate a new key and associate it to the saved file?
Does anyone have a realy simple php/javascript example of open a file for editing that works?
PelleH
