Document.key and collaborative editing
Postby thomaswollburg » Fri Nov 02, 2018 3:14 pm
we are setting up a quit extensive integration with OnlyoOffice Document server and I have a question about Collaborative editing and document.key attributes.
According to https://api.onlyoffice.com/editors/troubleshooting the key should be generated anew each time a document is save. Looking at the implementations for the NextCloud app etc this is confirmed.
But how do you see a scenario working where UserA opens a document, edits it, saves it. Then UserB opens the same document - but he will get a new key... how does Document Server do the matching of the Document? In our case the URL to the document is different for each user (as it contains the username).
Does DocumentServer manage "old" keys for documents? After UserA save the document, is there a way to get the new and correct document key into the active editing session?
thomaswollburg
Re: Document.key and collaborative editing
Postby Alexander_mb » Sat Nov 10, 2018 8:00 am
Hello thomaswollburg,
Please follow this https://api.onlyoffice.com/editors/coedit to find information in API documentation about how co-editing works.
UserB will see a blank file, because keys won't match.
No, unfortunately, there is no possibility to do this.
Alexander_mb
