Ask document saved location
Postby christbiz » Thu Nov 01, 2018 2:26 am
Hi, i'm using the OnlyOffice cloud service with document server. And i use docker to install. I found that saved document on /var/lib/onlyoffice/documentserver/App_data/cache/files
There's something i want to ask :
1. The folder is based on document key : ABC-1234_9292
What is 9292? Where the number come from?
2. What if i want change the location?
"editorConfig": {
"callbackUrl": "http://example.com/this-is-callback.php",
"createUrl": "http://example.com/location/folder/",
"user": {
"id": "78e1e841",
"name": "John Smith"
I have put the createUrl and it doesn't work.
Thank you in advance.
christbiz
Re: Ask document saved location
Postby Maxim » Thu Nov 01, 2018 7:38 am
Hello christbiz!
Document Server is not supposed to keep files or documents. It is not a storage for documents. You need to use your own Document Manager and integrate it with the Document Server. Please visit our API to know more.
Documents Server before collecting a file into a "ready-to-save" version has to keep data in its cache and this path is for cache files.
You need to generate document key using your Document Manager.
See here
