Drag & Drop on loaded Document
Postby tommycrestanello » Wed Sep 19, 2018 8:08 am
I'm here for asking if is possible manage Drag&Drop of text directly on loaded document on OnlyOffice.
I integrated OnlyOffice in my AngularJS application and the idea is to drag&drop from an external panel some text value.
The event Drag&Drop is supported directly or not?
tommycrestanello
Re: Drag & Drop on loaded Document
Postby Carl » Fri Sep 21, 2018 11:59 am
Text insertion via drag&drop is not supported.
Postby tommycrestanello » Fri Sep 21, 2018 1:55 pm
Thank you so much for the reply and feedback
tommycrestanello
