Inserting data on document with drag&qdrop
Postby tommycrestanello » Tue Sep 18, 2018 10:43 am
Hi
I'm integrating OnlyOffice in a document composition solution. My need is permit at the user to insert, via drag&drop variable or text inside the document. This feature is possible direct via API on document?
If yes,l exist on github any example?
Thanks in advance
8-)
tommycrestanello
Re: Inserting data on document with drag&qdrop
Postby Carl » Fri Sep 21, 2018 11:44 am
Unfortunately, such feature is currently not supported.
Users browsing this forum: No registered users and 5 guests
