Is the OnlyOffice API obfuscated or encrypted?
Postby fau.obregon » Mon Sep 17, 2018 8:39 pm
I want to know if the API of "OnlyOffice" or some of the methods of the document editor are obfuscated or encrypted for the editing of the code.
My doubt arises because I tried to edit the file "app.js" to adapt the "Change Control" function to the needs of my project and it does not show any changes, it does not even show the comments that I add to the code.
I would like to know if it is possible to edit that part of the "OnlyOffice Document Server" code, if the code is encrypted or obfuscated, and if so, what would be the procedure to be able to modify "OnlyOffice".
fau.obregon
