Do Community Server (Portal) Has API to Convert Docx -> PDF?
Postby coisox » Tue Jul 31, 2018 2:16 am
When I open a docx in Community Server (CS), I have option to save as PDF which is working perfectly. Do this feature has API?
coisox
Re: Do Community Server (Portal) Has API to Convert Docx ->
Postby Maxim » Fri Aug 03, 2018 7:40 am
Hello coisox!
Community Server is not able to convert files.
It converts on the side of the Document Server.
Postby coisox » Fri Aug 03, 2018 11:56 am
I found an API on Document Server but its JS (https://documentserver/web-apps/apps/ap ... nts/api.js)
Is there API for PHP CURL? My goal is to hide all the key/token/process behind server script.
coisox
Postby Maxim » Mon Aug 06, 2018 11:30 am
Hello coisox!
As i know there is no, also i do not see any reason to hide.
