Error 403 when downloading document changes
Postby oguerin » Mon Jul 02, 2018 2:49 pm
We have connected the Document Server (Docker version) with our PHP application through a callback page in PHP. When we try to download document changes from the url given by the document server, we get a 403 error :
        $downloadUri = $data_online["url"];
        $client = new Guzzle\Http\Client();
        $new_data = $client->get($downloadUri)->send()->getBody(true);
2018-07-02T15:57:19+02:00 DEBUG (7): Client error response
[status code] 403
[reason phrase] Forbidden
If we take the downloadUri (something like https://our.server.com/cache/files/10_9 ... 4wLFakeA==) and paste it in a browser, it works. We get the office document with all changes. But if we try to get it with a curl or wget request, we get a 403 error.
Best regards,
Olivier
oguerin
Re: Error 403 when downloading document changes
Postby Maxim » Tue Jul 03, 2018 6:21 am
Did you visit our API?
Postby oguerin » Tue Jul 03, 2018 8:22 am
Yes, we studied your API basic concepts, implemented the document storage service by following the Opening file section, Saving file section, learned that we have to deal with the Document history management. It works when we use http address, but not when we use https.
oguerin
Postby Maxim » Thu Jul 05, 2018 8:48 am
Did you install SSL certs?
Postby oguerin » Thu Jul 05, 2018 9:46 am
Yes, we genereated the certificates and followed instructions given here : https://helpcenter.onlyoffice.com/fr/server/docker/document/docker-installation.aspx
$sudo  docker run -i -t -d -p 8443:443 -v /u/apps/onlyoffice/data:/var/www/onlyoffice/Data -v /u/apps/onlyoffice/logs:/var/log/onlyoffice --net=bridge --name onlyoffice --restart=always onlyoffice/documentserver-de
8c906c1477277067cbae70e6e5bfc71877ee3f0e831c453dce627c6e7e9e346b
$ sudo docker logs -f onlyoffice
k * Starting PostgreSQL 9.5 database server                              [ OK ]
 * Starting RabbitMQ Messaging Server rabbitmq-server                    [ OK ]
Starting redis-server: redis-server.
Starting supervisor: supervisord.
 * Starting nginx nginx                                                  [ OK ]
Generating AllFonts.js, please wait...Done
onlyoffice-documentserver:docservice: stopped
onlyoffice-documentserver:docservice: started
onlyoffice-documentserver:converter: stopped
onlyoffice-documentserver:converter: started
 * Reloading nginx configuration nginx
In /u/apps/onlyoffice/data/certs, we have the following files :
[centos@test05 ~]$ cd /u/apps/onlyoffice/data/certs
[centos@test05 certs]$ ll
total 12
-rwxr-xr-x 1 110 114  424 13 févr. 15:34 dhparam.pem
-rwxr-xr-x 1 110 114 2171 14 mai   15:46 onlyoffice.crt
-rwxr-xr-x 1 110 114 1704 14 mai   15:46 onlyoffice.key
(we have changed permissions on file onlyoffice.key to 400, but it goes back to 755 every time we launch the container)
oguerin
Postby oguerin » Tue Jul 10, 2018 8:32 am
Hello, do you need more elements for our problem? Are there people having troubles integrating the Docker version of the Document Server in https?
Thanks for your advice.
oguerin
Postby Maxim » Tue Jul 10, 2018 11:16 am
Hello oguerin!
No.
https://our.server.com/web-apps/apps/ap ... nts/api.js - do you get API code?
Postby oguerin » Tue Jul 10, 2018 3:12 pm
Yes, we get API code :
oguerin
Postby oguerin » Fri Jul 13, 2018 12:52 pm
We have the same error in HTTP mode. We tested using file_get_contents instead of Guzzle and it works, in HTTP or in HTTPS mode.
Thank you for your assistance.
oguerin
