Use current style when inserting content
Postby bascouwenberg » Fri Jun 08, 2018 5:25 am
I am using OnlyOffice Integration and I wrote a plugin to insert text in a document. In this case the document has the Arial font but when I insert text it doesn't have the same font as the document. Instead it has the Georgia font.
How can I make sure whenever I insert text it gets the font used in the document or even better the style at the current cursor position?
The code:
var sScript = "var oDocument = Api.GetDocument();";
        sScript += "var oParagraph = Api.CreateParagraph();";
        sScript += "oParagraph.AddText(\"";
        sScript += text;
        sScript += "\");";
        sScript += "oDocument.InsertContent([oParagraph]);";
        window.Asc.plugin.info.recalculate = true;
        window.Asc.plugin.executeCommand("command", sScript);
I also tried callCommand with the same result as above.
bascouwenberg
Re: Use current style when inserting content
Postby Carl » Sat Jun 09, 2018 9:18 am
could you please attach your document so we are able to analyze the issue?
Postby bascouwenberg » Thu Jun 14, 2018 1:53 pm
For some reason I cannot attach a rtf file. Nothing happens when I try to. It is a simple file with some example text that has the Arial font. And when I now insertsome text into the document it doesn't have the Georgia font as a said earlier but the Liberation Serif font. The version of OnlyOffice is 5.1.3.
bascouwenberg
Postby bascouwenberg » Tue Jun 19, 2018 7:16 am
I get an error that the extensions rtf and docx are not allowed as attachments. What can I use to upload a document?
bascouwenberg
Postby Maxim » Wed Jun 27, 2018 6:41 am
Hello bascouwenberg!
ZIP
Postby bascouwenberg » Fri Jun 29, 2018 1:52 pm
I've attached the file.
onlyoffice.zip
(1.61 KiB) Downloaded 3 times
bascouwenberg
