PHP Example API remote client connection problem.
Postby napoleon211092 » Wed May 23, 2018 3:49 am
I have a problem when connection PHP Example API webserver.
I install the system as following:
1/ I install document server (developer edition), here is install link https://helpcenter.onlyoffice.com/server/developer-edition/linux/linux-installation.aspx.
This server has IP address : 192.168.131.146
2/ Then, I install webserver and use PHP Example API follow this link https://api.onlyoffice.com/editors/example/php.
This server has IP address: 192.168.131.144.
I also edit file config.php as:
$GLOBALS['DOC_SERV_CONVERTER_URL'] = "https://192.168.131.146/ConvertService.ashx";
$GLOBALS['DOC_SERV_API_URL'] = "https://192.168.131.146/web-apps/apps/api/documents/api.js";
$GLOBALS['DOC_SERV_PRELOADER_URL'] = "https://192.168.131.146/web-apps/apps/api/documents/cache-scripts.html";
After installed successfully, I try:
- Stay on server 192.168.131.144, open web browser and type http://localhost/PHP%20Example/ view and edit office file --> it's worked!
- But, when I used to use another computer (have IP address: 192.168.101.58), open browser and type http://192.168.131.144/PHP%20Example/ ---> It appears in the web pages similar, I can upload files, but can not display or edit file (unknow error!!!)
P/S:
All three machines can communicate with each other (I have check with ping cmd). Both server (192.168.131.146 and 192.168.131.144), I install in VMware and 192.168.101.58 is real computer.
I attack system scheme and the error.
System scheme
Please help me.
Thanks.
napoleon211092
Re: PHP Example API remote client connection problem.
Postby Maxim » Wed May 23, 2018 8:06 am
Hello napoleon211092!
I suppose that 192.168.101.58 machine has no access proper to the document server.
Try to use wget command. It's possible that you can ping your host but you has no a chance to get proper connection.
Users browsing this forum: Baidu [Spider] and 2 guests
