How to set alternate text for table/image/chart using API
Postby virtuaresearch » Wed May 02, 2018 8:43 am
In only office editor, there is option in advance setting of table/image /chart to set alternative text for the object.
We are looking for API method to set alternative text to table/image /chart in document editor of onlyoffice using java-script. I referred to Only Office ApI documentation for table and other objects but couldn't find any solution.
Please let us know is there any way to add alternative text to table in document editor using java-script in .net
Only office team suggested to use ContentControls for now, but i am not able to implement it with image and table. Even paragraph sample is not working for me :(
virtuaresearch
Re: How to set alternate text for table/image/chart using AP
Postby Maxim » Fri May 11, 2018 8:25 am
Hello virtuaresearch!
Unfortunately there is no such option, no way to add alternative text to table.
