REST APi (or similar)
Postby morten » Wed May 02, 2018 6:18 am
Hi.
I have a trial trying to see if OnlyOffice is the right thing for me.
I need to create documents from our other systems (reports risk management) where I aggregate data from a set of services and have them put in a specific account.
1: When looking at the API section of the docs, it seems to only offer API to embed documents in other webpages but not functionality top open|create, edit and save documents from my own tools.
Is that correct?
2: If now, can somebody please point me to the correct documentation?
Cheers,
Morten
morten
Re: REST APi (or similar)
Postby Maxim » Fri May 11, 2018 9:52 am
Hello morten!
Maybe you need to take a look at Document Builder.
When looking at the API section of the docs, it seems to only offer API to embed documents in other webpages but not functionality top open|create, edit and save documents from my own tools. Is that correct?
No, you can save. open or edit documents using API.
