Settings Regional - México
Postby oscar » Wed Feb 07, 2018 4:09 pm
hello, I hope you can help me, I'm using onlyoffice with owncloud, each one is on a pc with ubuntu 16.04 LTS, I want to edit documents online but when working with currency the regional format puts me euros and I need to change it to the Mexican currency (pesos ).
Does anyone know if onlyoffice offers this option? :?:
Is there any way to add it?´ :?:
oscar
Re: Settings Regional - México
Postby Maxim » Mon Feb 12, 2018 10:58 am
Hello oscar!
1. Please specify what Onlyoffice version you have installed or what instruction you followed to install Onlyoffice.
2. Please attach your screenshot of the issue. Where you would like to set up Mexican currency (pesos)?
Postby oscar » Tue Feb 13, 2018 6:18 pm
Maxim wrote:Hello oscar!
thanks for answering,
I followed the following tutorial to install onlyoffice: https://www.linuxbabe.com/ubuntu/integr ... -nextcloud
The owncloud is in version 10.0.5, the onlyoffice API is in 1.2.0, when creating an excel sheet in owncloud, and I want to work with numbers and apply a currency format only the options that come in the screenshot.
Imagehttps://ibb.co/cLEw5n
Imagehttps://ibb.co/eFC5y7
I do not know if onlyoffice has the option to change the regional settings and I can establish that I use regional data from Mexico, (currency, time, etc.)
Perdona por la traduccion, estoy utilizando google :)
Thanks for the help
oscar
Postby Maxim » Wed Feb 14, 2018 7:42 am
Hello oscar!
Thank you for your feedback!
Now it's clear for me what you mean and what you want.
no hay problema, yo también puedo :D :D :D
