How to clear the header?
Postby robertotomas » Fri Jan 05, 2018 3:44 pm
Using the api I currently can set the header with a call like:
var oDocument = Api.GetDocument();
var oParagraph, oDrawing;
var oSection = oDocument.GetFinalSection();
oHeader = oSection.GetHeader("default", true);
oParagraph = oHeader.GetElement(0);
oDrawing = Api.CreateImage("https://www.newyorksightseeing.com/media/wysiwyg/GLNY/nyss_newyorkcity_roptimized.jpg.jpg", 60 * 36000, 35 * 36000);
oParagraph.AddDrawing(oDrawing)
This is great when I want to attach an image once there .., but when I want to replace what is in the header, how can I do that?
Similarly, I have a question about selections. Is it possible to select text, paragraph, etc? Or to move the cursor?
robertotomas
Re: How to clear the header?
Postby Maxim » Tue Jan 09, 2018 7:42 am
Hello robertotomas!
It's not possible to replace an image for now, but it will be added later.
Selection will be added later too.
The cursor can be moved, but undocumented.
Postby robertotomas » Tue Jan 09, 2018 4:40 pm
Hmm, can I get the current paragraph (the paragraph the cursor is currently in)? How do I do it?
robertotomas
Postby Maxim » Wed Jan 10, 2018 7:26 am
Hello robertotomas!
No, there is no selection for now
